LDG
Apr 19, 2016Aspirant
WD Compatibility
Two questions: 1. I have two WD Elements and one WD My Book. I did a brief search for compatibile drives with the 104 and only came up with about three for WD. Is that right or was I looking i...
LDG
StephenB wrote:
LDG wrote:Two questions:
1. I have two WD Elements and one WD My Book. ...Will my drives work in this NAS?
These are USB drives, correct? The HCL Brian mentions is for internal hard drives that are installed in the NAS.
The NAS is not a USB dock - it is intended to be used with internal drives like the WD40EFRX.
You are correct! My plan is to remove the drives from their enclosures. Way out of warranty on all three. I forgot to mention that detail when I posted this. Will this still work?
Apr 19, 2016Guru - Experienced User
It might work - not all drives are well-suited for RAID. You will likely be denied support from Netgear if you run into problems.
IMO It'd be better to get new drives.
- LDGApr 19, 2016Aspirant
StephenB wrote:
LDG wrote:You are correct! My plan is to remove the drives from their enclosures. Way out of warranty on all three. I forgot to mention that detail when I posted this. Will this still work?
How would I find out if these drives are well-suited?
- StephenBApr 19, 2016Guru - Experienced User
If they were desktop drives, then a google search would probably tell you (since a fair number of other folks would have already tried them). There probably is no good way in your case.
StephenB wrote:
LDG wrote:How would I find out if these drives are well-suited?
I'm trying to get a server in my house that will support these hard drives so that they aren't reliant on one computer to be accessed. I had a NAS recommended to me, however that requires me to remove the actual drives from their external enclosures. After they are supported, I might just go the internal route and definitely use NAS's if I'm not already. You don't seem too keen on the use of a NAS here though and I can understand why. My question becomes though; given my current hardware, what is your recommendation for reaching my goal?
