LDG
Apr 19, 2016Aspirant
WD Compatibility
Two questions: 1. I have two WD Elements and one WD My Book. I did a brief search for compatibile drives with the 104 and only came up with about three for WD. Is that right or was I looking i...
LDG
Apr 23, 2016Aspirant
Let's say I buy a 2 bay disk less NAS and then a 1 tb to put in it. Once that is used up and I buy the second drive, will I have to format the first when adding the second?
- StephenBApr 23, 2016Guru - Experienced User
LDG wrote:
Let's say I buy a 2 bay disk less NAS and then a 1 tb to put in it. Once that is used up and I buy the second drive, will I have to format the first when adding the second?There are two basic scenarios, depending on whether you are using jbod or xraid. Either way the NAS formats the drives.
With jbod, the simplest thing to do when the disk is full is to add a second disk (which would be its own volume). After that second disk becomes full, you'd need to get a larger one, destroy the first volume, remove the drive, and install the new larger disk. All data on the volume is lost, so you need to restore it from a backup,
With xraid, you actually want to start with 2 disks (say 2 x 1 TB). When you need to expand, you buy two larger replacements (say 2x4TB). First you'd insert the first 4 TB drive (with the NAS running). After the volume resyncs, you'd replace insert the second 4 TB drive (again with the NAS running). The NAS will then expand the volume to the larger size. There is no loss of data.
- LDGApr 26, 2016Aspirant
Xraid sounds much better...pretty much what I do anyway, actually. The downside is finding a way to keep the the first disks connected. I simply like having constant access to everything. Xraid allows for expansion the way I would like it to, but then I still have two disks that I'd like to continue to be accessible.
- StephenBApr 26, 2016Guru - Experienced User
There might be still be some confusion here on what RAID actually does. XRAID creates a single volume (think of it as a "virtual disk") from the physical disks you have installed. By default the NAS calls this volume "data".
All your data is on this virtual disk, and you expand it by replacing the physical disks with larger sizes. All the data remains accessible when you expand - nothing is destroyed (unless something goes wrong).
Also, if a single disk in the volume fails, the volume is "degraded". But you still have all your data available. You pop in a new disk (either the same size, or matching the size of the largest disk in the array), and the redundancy is restored.
This doesn't keep your data completely safe (so you still need a backup). But it does keep everything available through routine disk replacements.
So with XRAID it actually doesn't make sense to say "I still have two disks that I'd like to continue to be accessible.", since the disks are all combined into the virtual disk.
