jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
May 04, 2014Guru - Experienced User
The raw read error rate "stores data related to the rate of hardware read errors that occurred when reading data from a disk surface. The raw value has different structure for different vendors and is often not meaningful as a decimal number" http://en.wikipedia.org/wiki/S.M.A.R.T. ... attributes
So its not clear how high the number is. All but one of my red drives has 0 though - the exception has a 2.
