jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
mdgm-ntgr
May 05, 2014NETGEAR Employee Retired
If you format the USB disk to use e.g. EXT3 then performance should be considerably quicker.
Both NAS units you've got are entry level. If you replace an entry-level system with a newer entry-level system you could expect perhaps to get a little better performance than before but still entry-level performance.
If you want fast USB performance getting a NAS with a fast Intel CPU is the way to go.
