jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
May 05, 2014Guru - Experienced User
True with most gadgets I think. But perhaps more true with NAS (no matter what vendor you use). Some knowledge of RAID, Linux, and protocols helps.
jhbingham wrote: seems you need more than ''entry-level'' knowledge to know how to get the most out of the readynas!
