jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
May 06, 2014Guru - Experienced User
If Lifeguard is saying the the disk failed, then I suggest getting another. If you can still exchange it at the seller, you will get a new one. If you RMA it to Western Digital, they will give you are recertified return (unless you can somehow argue them into a new one).
Not sure what is happening on disk 1. You might check the logs.
