jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
May 07, 2014Guru - Experienced User
No formatting - the duo v2 will redo that anyway.
Use jbod (two volumes), otherwise a failure of either drive will result in losing everything.
You'll be limited by the duo v2 performance, not much by the drives. So I don't see any need to tweak power save, etc.
