jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
May 07, 2014Guru - Experienced User
I don't own a v2, but my understanding is that the memory is soldered onto the system board.
The duo v2 is faster than the v1, but it didn't last long enough for all the features to get into its firmware.
On RAID0, I still prefer jbod. You do need to balance storage between the two volumes, but getting it back up after a failure is quicker. You won't see any performance gain with single-volume RAID0, since the CPU is the bottleneck, followed by the network. Anyway, jbod is what I use on my RN102.
