jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
May 07, 2014Guru - Experienced User
jbod = "just a bunch of disks" See pages 20 and following in your user manual. http://www.readynas.com/download/docume ... Nov711.pdf
jbod does gives you 6 TB total - 3 TB in a "C" volume on disk 1, and 3 TB in a "D" volume on disk 2.
RAID0 by contrast gives you 6 TB in a "C" volume. The aggregation into 1 volume is convenient, but reliability suffers.
