jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day, Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to...
jhbingham
May 07, 2014Aspirant
Thanks for that! I can see that JBOD is definately more beneficial in the long run. I thought having the RAID0 would speed read/write speeds up, but I guess not going by what you say about the CPU.
If i insert my good disc from the xraid2 and the new blank disc, is the readynas able to switch over to JBOD and make two volumes like you mention? so i dont have to copy ALLL 2.7TB of data from my backup onto one of the newly created volumes?
Otherwise, I guess i will want to erase everything on the old disc and start afresh.
Thanks StephenB
Thanks StephenB
