jhbingham
May 04, 2014Aspirant
WD Red 3TB high RawReadErrorRate
Good day,
Using a ReadyNAS Duo v2 I have almost reached my 3TB capacity in X-RAID2 mode. I was looking to expand, and upon checking the SMART status of the two discs, I have found, what I believe to be problems with the DISC2.
For my peace of mind, i have just started a full backup of the NAS.
I am then relying on people here to advise me what to do next. I need more capacity, and was planning to convert the RAID to give me 6TB capacity. However, to do that, I will maybe need to buy a new WD 3TB RED.
What are peoples thoughts here?
I also notice that when playing GoPro3HD footage from the NAS to my iMac, I experience a lot of jitter. I think it is my mac that causes that.
Thank you
SMART Information for Disk 1
Model: WDC WD30EFRX-68AX9N0 2794 GB
Serial Number: WD-WMC1T0570XXX
Firmware Version: 80.00A80
SMART Attribute
Raw Read Error Rate: 0
Spin Up Time: 6050
Start Stop Count: 3661
Reallocated Sector Count: 0
Seek Error Rate: 0
Power On Hours: 8504
Spin Retry Count: 0
Calibration Retry Count: 0
Power Cycle Count: 30
Power-Off Retract Count: 25
Load Cycle Count: 3635
Temperature Celsius: 33
Reallocated Event Count: 0
Current Pending Sector: 0
Offline Uncorrectable: 0
UDMA CRC Error Count: 0
Multi Zone Error Rate: 0
ATA Error Count: 0
SMART Information for Disk 2
Serial Number: WD-WMC1T0573XXX
SMART Attribute
Raw Read Error Rate: 102
Spin Up Time: 6508
Start Stop Count: 3645
Seek Error Rate: 0
Power On Hours: 8505
Spin Retry Count: 0
Power Cycle Count: 29
Power-Off Retract Count: 24
Load Cycle Count: 3620
Temperature Celsius: 34
Current Pending Sector: 3
ATA Error Count: 0
Thank you
- StephenBGuru - Experienced UserUnfortunately you need to start fresh - the older NAS have no ability to switch between flexraid and xraid. OS6 does (with some limitations), of course you can only run 5.x.
My advice is to start with just the new disk installed in slot 1, and choose flexraid/jbod. After that setup completes, hot-insert the old disk in slot 2. There are two reasons
(a) if the initial setup fails for some reason, you still can fall back to your old setup by reinstalling the old disk in slot 1 with the NAS off.
(b) It makes it a little more difficult to accidentally end up in RAID1 (or RAID0) - jhbinghamAspirantok. the moment of truth!
- jhbinghamAspirant
StephenB wrote: Unfortunately you need to start fresh - the older NAS have no ability to switch between flexraid and xraid. OS6 does (with some limitations), of course you can only run 5.x.
Might have made a mistake.
First disk installed and firmware installed. THEN inserted the disk2, and the nas saw that new disk being inserted.....how do i get it as the 2nd volume and to be made blank? - jhbinghamAspirant
jhbingham wrote: StephenB wrote: Unfortunately you need to start fresh - the older NAS have no ability to switch between flexraid and xraid. OS6 does (with some limitations), of course you can only run 5.x.
Disregard - it just appeared as the d:!
Thanks for AL your help!
