f0rgiven
Sep 03, 2016Aspirant
Weird Problems
ReadyNAs pro 4 with latest firmware and 4x 3TB drives. When i login to the admin console and click "shares", nothing shows there not even the default shares. If i use SSH to connect to the NAS, putty...
mdgm-ntgr
Sep 04, 2016NETGEAR Employee Retired
Sounds like you are trying to login to SSH as the admin user rather than the root user.
If you have SSH enabled and have logged in as 'root' you can run e.g.
# df -h
# df -i
Welcome to the community!
f0rgiven
Sep 05, 2016Aspirant
So it looks like the root filesystem is full:
#df /
Filesystem 1K-blocks Used Available Use% Mounted on
- 4176564 4176564 0 100% /
How can i find what is taking up the space?
- mdgm-ntgrSep 05, 2016NETGEAR Employee Retired
By using the du command.
e.g.
# du -csh /var/*
# du -csh /var/log/*Note the df commands I provided in my previous post were to check for two different ways that the 4GB root partition may be full. Almost always it would be full one way, but not the other. There would be a different approach that would need to be taken if all the inodes were used up.
- f0rgivenSep 05, 2016Aspirant
Thanks for your help! I found what was taking up the space. It was tmp. So i deleted some of the tmp files and restarted the NAS. Now, i can't connect via ssh (get connection refused). Not sure how to even get to it now without SSH. Is there a console that i can connect through?
Freeing up space is only the first step.
What was filling up /tmp ? Crashplan?
With your 4GB root partition full it's likely some config was corrupted.
There is tech support mode (a boot menu option). The credentials for logging into that using telnet are freely available on the web, but using that would have the same implications as using SSH.
It's likely your /etc/default/services file on the 4GB root partition is corrupt.You could copy the default one from /etc/default/config/etc/default/services and add the lines
APACHESSL=1
SSH=1Other config files may be corrupt too e.g. /etc/network/interfaces
