RDD
Dec 22, 2016Guide
Weird USB behaviour
Hardware: RN204 @ 6.6.0 with 3 WD 4 TB Red and 1 Samsung 1.5 TB Sabrent 2 bay USB 3 docking station Toshiba 3 TB WD 4TB Red 2 brand new Segate ST4000DM000 4 TB I have been using the WD...
- Jan 07, 2017
Bought an inateck FD2102 USB3 Dual Docking Station from Amazon. It had absolutely no problem bringing up the two Seagate 4 TB drives. Have been backing up from RN204 to it for five days now. Working great.
So since Sabrent does not support USB to anything but Windows or Mac, then the solution must be to not use Sabrent. Or Seagate?
I had thought that since the interface was USB that the operating system would be irrelivant.
I do see that the inateck box says "Support OS: Windows XP, Vista, 7, 8, 8.1 (32,64 bit), Mac". So, offically, it does not support Win 10 or Linux. But it had no problem formating the drives to EXT4 on the RN204.
I bought my first PC in 1982. After 35 years I should be used to doing this stuff by trial and error.
mdgm-ntgr
Dec 22, 2016NETGEAR Employee Retired
This does sound quite odd. Do you still see this on ReadyNASOS 6.6.1-T230 (Beta 4) ?
RDD
Dec 23, 2016Guide
Had not seen that. Unfortunately I tried hot swapping, powering down the docking station and rebooting the RN204. Nothing helped.
