ryan_g
Nov 21, 2015Aspirant
Went from reallocated sector count increase warning to no detected volumes
I have a ReadyNAS Ultra 2 that's been running fine for 3 years but starting today the volumes are no longer accessible. It looks like I missed out on reallocated sector count emails due to an SMTP ...
- Nov 22, 2015
Do you have a backup?
Try shutting it down, removing disk 1, and then booting up again - and see if the volume shows up again.
If it doesn't (and you have no backup), you should contact support.netgear.com (they will likely charge). It's possible that they can remount the volume, they also have a data recovery service. Data recovery (no matter who does it) is expensive, and might not succeed.
Nov 22, 2015Guru - Experienced User
- ryan_gNov 22, 2015Aspirant
No backup, so some lessons to be learned there.
Pulled Disk 1 and all the files are there. I've powered off the machine till a new disk can arrive and I can get that in to rebuild.
Also going to purchase an external drive to start having actual backups.
Thanks.
- BrianL2Nov 23, 2015NETGEAR Employee Retired
Hi ryan_g,
Consider a hard drive that is listed in our hard drive compatibility list. Once you have the replacement handy, insert it on slot 1 and just wait for the resync process to complete.
Let us know if you have other questions.
Kind regards,
BrianL
NETGEAR Community Team
