Jaroslaw
Sep 22, 2015Guide
What Bonding/Teaming Mode Should I Use?
Hello, I am seeking your advice on Which Bonding/Teaming Mode Should I Use to achieve best performance? ReadyNas 204 connected directly to Nighthawk X6 R8000 What settings would you recommend me ...
- Sep 22, 2015
What settings would you recommend me to use, please?
Thanks
Jarek
You can't use LACP, since both ends need to support it (and the R8000 doesn't). I think Adaptive Load Balancing (ALB) is the best mode of the ones that are left.
Generally speaking, bonding/teaming only helps if you have multiple users accessing the NAS at the same time.
Sep 22, 2015Guru - Experienced User
Thanks
Jarek
- JaroslawSep 29, 2015Guide
Thanks for your advuice,
there is few of us in my household to use our NAS.
Thanks again!
