Jaroslaw's avatar
Sep 22, 2015
What Bonding/Teaming Mode Should I Use?
Hello, I am seeking your advice on  Which Bonding/Teaming Mode Should I Use to achieve best performance? ReadyNas 204 connected directly to Nighthawk X6 R8000 What settings would you recommend me ...
  • StephenB's avatar
    Sep 22, 2015
    What settings would you recommend me to use, please?
    Thanks
    Jarek
    You can't use LACP, since both ends need to support it (and the R8000 doesn't).  I think Adaptive Load Balancing (ALB) is the best mode of the ones that are left.
    Generally speaking, bonding/teaming only helps if you have multiple users accessing the NAS at the same time.
ProSupport for Business
