Sloth32
May 04, 2017Aspirant
What is a (null)+ffffffff88ec2940 error mean on main display ?
Hi, I've been getting this error on the front display of my NAS for a while on and off. I've rebuilt the array and it made no difference. My cuurent setup is a Raid 5 setup with 6 x 4tb drives. C...
JennC
May 04, 2017NETGEAR Employee Retired
Hello Sloth32,
Aside from getting this error message, what other problems are you experiencing with the NAS?
If you can get to the admin page, please PM me the logs.
- Sloth32May 04, 2017Aspirant
Nothing that I can see issue wise in the system, everything seems ok. It jsut keeps showing this error. Also the logs do go back quite some time, but please take note that I just recenetly rebuilt my drive share on Sunday night so all of the data from before then is no longer exitent on the drives (As Im sure you will notive a few virus warnings previous to that date in the logs). PM'ing you the logs.
- JennCMay 05, 2017NETGEAR Employee Retired
Hi Sloth32,
Did you factory reset before rebuilding the volume? I think you meant volume when you said drive share, correct me if I'm wrong, please.
- Sloth32May 05, 2017Aspirant
Correct, I meant the Volume.
No, I did not do any sort of factory reset on the system before deleting the old volumes and building the new one.
