Sloth32
May 04, 2017Aspirant
What is a (null)+ffffffff88ec2940 error mean on main display ?
Hi, I've been getting this error on the front display of my NAS for a while on and off. I've rebuilt the array and it made no difference. My cuurent setup is a Raid 5 setup with 6 x 4tb drives. C...
JennC
May 05, 2017NETGEAR Employee Retired
Hi Sloth32,
Did you factory reset before rebuilding the volume? I think you meant volume when you said drive share, correct me if I'm wrong, please.
Sloth32
May 05, 2017Aspirant
Correct, I meant the Volume.
No, I did not do any sort of factory reset on the system before deleting the old volumes and building the new one.
- JennCMay 05, 2017NETGEAR Employee Retired
Hello Sloth32,
If there is no data or if there was then backup the data, factory reset the NAS from the boot menu.
Hello Sloth32,
Not sure, frankly, but I'm checking with others who possibly have ideas.
