Sloth32
May 04, 2017Aspirant
What is a (null)+ffffffff88ec2940 error mean on main display ?
Hi, I've been getting this error on the front display of my NAS for a while on and off. I've rebuilt the array and it made no difference. My cuurent setup is a Raid 5 setup with 6 x 4tb drives. C...
Sloth32
May 05, 2017Aspirant
I just re copied all the data back on....
What does the error code mean?
- JennCMay 05, 2017NETGEAR Employee Retired
Hello Sloth32,
It must have something to do with an app that has been installed that caused a failure. You might want to check the apps that you add to the NAS after setting up the volume.
- Sloth32May 05, 2017Aspirant
Thank you. I'll check them. All of them were pulled through the Readynas App "Store" except for one which I downloaded although I did have an older version fo hte application on the system before re doing the volume.
