Sloth32
May 04, 2017Aspirant
What is a (null)+ffffffff88ec2940 error mean on main display ?
Hi, I've been getting this error on the front display of my NAS for a while on and off. I've rebuilt the array and it made no difference. My cuurent setup is a Raid 5 setup with 6 x 4tb drives. C...
Sloth32
May 05, 2017Aspirant
I just re copied all the data back on....
What does the error code mean?
JennC
May 05, 2017NETGEAR Employee Retired
Hello Sloth32,
It must have something to do with an app that has been installed that caused a failure. You might want to check the apps that you add to the NAS after setting up the volume.
- Sloth32May 05, 2017Aspirant
Thank you. I'll check them. All of them were pulled through the Readynas App "Store" except for one which I downloaded although I did have an older version fo hte application on the system before re doing the volume.
