Dewdman42
Apr 12, 2016Virtuoso
what is leafp2p?
what is leafp2p running on my system? I understand its somehow related to readynas remote or readynas replicate, neither of which I will ever use. Is leafp2p used for anything else? It ends up cre...
- May 09, 2016
I can report that his problem has been solved in 6.5.0 RC3, leafp2p should not be left running anymore unless Netgear cloud services are being used. That is my experience with RC3 so far.
mdgm-ntgr
Apr 12, 2016NETGEAR Employee Retired
If you don't use any of the cloud services you could try doing e.g.
# systemctl stop leafp2p
# systemctl disable leafp2p
Dewdman42
Apr 13, 2016Virtuoso
So that would include ReadyCloud, ReadynasRemote, ReadynasReplicate? Anything else that requires this service running?
I am thinking about messing around with ReadyCloud at some point, but I'm not sure I really need it. I'm assumign that if I decide I want to use those again I would just do the following to renable it again later:
systemctl enable leafp2p systemctl start leafp2p
Yes? where does the actual .service file for leafp2p get stashed?
- Jul 11, 2018Retired_Member
