Blueray3's avatar
Jul 08, 2018
readycloud android app not connecting
In past several days, can no longer login to ReadyCloud account with android mobile app.  Colleague on different ReadyCloud account having same problem.  I can login from Windows ReadyCloud app, and ...
  • Retired_Member's avatar
    Retired_Member
    Jul 11, 2018
    Hi
    If you are facing VPN disconnected issue on Android app or Windows client,please turn off and turn on ReadyCLOUD service in admin UI or simply reboot the device to force restart leafp2p service.after that you will be able to get VPN connection again.
ProSupport for Business
