whitebear_99's avatar
whitebear_99
What is the filesystem RN316 using as raid.
I have 6 raid disk used in RN316
Now I connected to these disks to another  machine and assmble the raid.
$sudo mdadm --assemble /dev/md130 /dev/sdf3 /dev/sde3 /dev/sdd3 /dev/sdc3  /dev/sdb3
mdadm: /dev/md130 has been started with 5 drives.
However, I can not mount this,
$sudo mount /dev/md130 /mnt/raid
mount: you must specify the filesystem type
it requre the filesystem type.
So I try this but in vain....
$sudomount -t ext4 /dev/md130 /mnt/raid
mount: wrong fs type, bad option, bad superblock on /dev/md130,
       missing codepage or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
Raid looks working
$sudo mdadm -D /dev/md130
/dev/md130:
        Version : 1.2
  Creation Time : Wed Jun 11 08:24:46 2025
     Raid Level : raid0
     Array Size : 39045879040 (37237.05 GiB 39982.98 GB)
   Raid Devices : 5
  Total Devices : 5
    Persistence : Superblock is persistent
    Update Time : Wed Jun 11 08:24:46 2025
          State : clean
 Active Devices : 5
Working Devices : 5
 Failed Devices : 0
  Spare Devices : 0
     Chunk Size : 64K
           UUID : 5cda431d:eb21dd6d:849d9d92:636a0c72
         Events : 0
    Number   Major   Minor   RaidDevice State
       0       8       83        0      active sync   /dev/sdf3
       1       8       67        1      active sync   /dev/sde3
       2       8       51        2      active sync   /dev/sdd3
       3       8       35        3      active sync   /dev/sdc3
       4       8       19        4      active sync   /dev/sdb3
$less /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [multipath]
md130 : active raid0 sdf3[0] sdb3[4] sdc3[3] sdd3[2] sde3[1]
      39045879040 blocks super 1.2 64k chunks
1 Reply
  • StephenB's avatar
    Please use just one discussion thread.
    Can you show us the partition information for all the drives?
    Do you know if the NAS volume was ever vertically expanded?
    Is BTRFS installed on the linux system?
ProSupport for Business
