viperhansa
Jan 12, 2022Virtuoso
What is these folders in Admin home folder?
Hi, im running a leagcy pro 6 with os 6.10.6 and have been using os 6 for a long time. (hence no need for comments on support and stuff.. ) :smileyhappy: My question is: What is this for f...
- Jan 12, 2022
It's not that you have installed something there - much more (specifically Python) and many more applications are using the U**x home folders for storing stuff, run time data, and and and ...
Another example is ssh - the home folder is used to store accepted keys for example, by user. The location of the home folder is typically referred in Linux (or more global U**x-like OS) as ~/ , the location is defined in passwd (like /etc/passwd or in a enterprise directory (AD, LDAP, ...). If you have some basic Windows or Mess-DOS insight, you might remember autoexec.bat ... each shell does also have it's specific counterpart for it's "logon" script in the every same home folder.
viperhansa
I cannot recall that i have installed anything related to home folders....
The path for my 2 different version is as follows:
/usr/lib/python37.zip /usr/lib/python3.7 /usr/lib/python3.7/lib-dynload /usr/local/lib/python3.7/dist-packages /usr/lib/python3/dist-packages /usr/lib/python2.7 /usr/lib/python2.7/plat-x86_64-linux-gnu /usr/lib/python2.7/lib-tk /usr/lib/python2.7/lib-old /usr/lib/python2.7/lib-dynload /usr/local/lib/python2.7/dist-packages /usr/lib/python2.7/dist-packages
anything else i can check?
schumaku
Jan 12, 2022Guru - Experienced User
- viperhansaJan 12, 2022Virtuoso
I leave it as is, just 35mb so.....
Thanks for your reply!
