eton
Nov 23, 2012Luminary
When is CIFS and NFS needed?
When is CIFS and NFS needed or used? The only thing I know is that NFS is used if you make backups of the nas over internet.
Nov 23, 2012Guru - Experienced User
It is harmless - in fact it is reasonable to disable protocols you don't use.
eton wrote: Anyway, is it harmless to disable NFS if I don't access the nas from linux or backup over internet?
