7lkf7's avatar
7lkf7
Why My ReadyNAS PRO is 1T less than the Raid Calulator
Hi everyone, I did use the Netgear Xraid calculator configured my raid setup, three 4TB drives, one 2TB plus two 1TB drives in X-RAID . refer to Calculator I should get 10.9TB in total. but my real...
  • Marc_V's avatar
    Marc_V
    Mar 28, 2018
    Hi 7lkf7
    You can perform factory reset if you want but make sure you have backed up all your data. You may want to wait for StephenB 's advise once the log has been checked.
    Doing factory reset removes all data so make sure everything has been copied or updated. I'm pretty sure what the calculator is showing will be the same with your volume after the factory reset.
    Regards
ProSupport for Business
