dennislv
Jul 09, 2019Aspirant
Why was my previous message deleted?
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN-626X-6-10-1-Active-directory-Import-Error-rndb-account-c-2473/m-p/1772410/thread-id/181111
Sandshark
Jul 09, 2019Sensei
Something is likely causing them to get caught up in the SPAM filter, so an admin has to release them. I can get to the first, but not the second.
Marc_V
Jul 10, 2019NETGEAR Employee Retired
Welcome to the Community!
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/RN-626X-6-10-1-Active-directory-Import-Error-rndb-account-c-2473/m-p/1772410/thread-id/181111 is actually available and can be viewed on the Community while https://community.netgear.com/t5/New-ReadyNAS-Users-General/The-admins-decided-to-delete-my-previous-post-of-this/m-p/1772566#M37269 is marked as spam and will not be released since there's already a duplicate entry. The Community is a place where users and experts share knowledge and experiences with their devices so we are here to help and will not prohibit anyone from using it unless Guidelines are not followed.
We also don't recommend posting your logs publicly as it may compromise privacy. I suggest avoiding posting it publicly so it will not be automatically detected as Spam.
I suggest opening a case on my.netgear.com and contact Support for assistance on the issue you are having so L3 will be able to check on this.
HTH
Regards
- dennislvJul 10, 2019Aspirant
Thank you Marc_V for clarifying. I would have contacted support directly, but my 90 days are up and its going to cost me $380 to chase a bug that seems to go back a few versions. Is this my only option?
Even filing a 'bug report' it tells me to go away.
Purchase Technical Support Your complimentary 90 days technical support expired on 2019-03-03. Purchase a support contract for additional technical support. You can purchase a paid support subscription to extend your coverage. Your product is covered under hardware warranty till 2023-12-02. To request warranty replacement, please Click Here Our experts will verify the hardware issue and process warranty replacement if necessary.
