hxroberts
Mar 20, 2023Aspirant
Nighthawk RAX45 - can not change SSID back to previous
In doing a firmware update, a factory reset was somehow done, changing my SSID and PW back to the original which matches the stickers on the device. I then went and tried to change the SSID and PW back to what I had setup and I get the error message that the SSID is a duplicate and to please change to a new one. I tried both via the Nighthawk app and the web browser. I have no backup. Is it possible to get it back to using my old one?
My apologies for the delayed response/resolution but I've been away and recently returned to resolve this. As it turns out, I had an N300 WiFi range extender in the garage for the home security cameras and this was not allowing me to change back to my network name. I removed this first and then was able to make the changes desired, then reconnected the extender and all is now good. Thanks for all of your help.
It's recommended to change the SSID name to a custom name other than what comes as default on the sticker.
- hxrobertsAspirant
It was changed to a unique SSID and PW when it was setup in late 2020. I've been doing firmware updates and this is the first time it somehow did a factory reset. I want to change it back to what I had setup as my SSID.
Did you do a FR from the reset button in back or from the Backup menu in the web UI using the erase button there?
