alokeprasad's avatar
Nov 23, 2012
Will a Duo v1 (RAIDiator 4.1.8) backup to a 3 TB USB?
Can it handle a 3 TB USB drive attached to it for use in Backup?
I am upgrading my Duo to 2 x 2TB XRAID setup and a 2 TB external USB drive may no longer be sufficient for backups ....
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    There is no support for disks larger in 2TB in capacity either internal or external.
  • StephenB's avatar
    You could connect the 3 TB USB drive to a PC, and backup over the network. The main disadvantage is that the PC would need to be turned on when the backup is scheduled (and left on until it completes).
    If you are sticking with X-Raid, your current USB drive should be ok (unless you are storing multiple backups on the same drive). After expansion, the duo's volume should be slightly smaller than the external drive size.
  • I'm OK with one backup set on my USB drive.
    But I have the backups set to "Full backup once every week". If I select "Remove the contents of the backup destination before a full backup is performed." then there will be a short period (well, with the backup speeds I see, more like a day and a half!) when I won't have any backup (before the current full backup is completed).
    If there was an option to 'Replace files on destination when doing full backup", that would be better, IMO.
ProSupport for Business
