fbmachines
Jul 06, 2011Guide
WOL with NIC Teaming
I have 3 x86 NASs (running 4.2.17) each with LACP NIC Bonding and WOL enabled. All three NASs are connected to a HP Procurve V1810g-24 switch also with LACP configured for the required ports. Here...
fbmachines
Jul 14, 2011Guide
Thanks for the reply OptimusPrime.
I tried the same setup on my Netgear GS724Tv3 (LACP enabled) and the WoL worked no problem.
I have other issues with the GS724Tv3 so I won't use it as my main switch but I wanted to test this scenario on it.
So it looks like an issue with the HP Procurve 1810. Will keep you posted though.
