fbmachines
Jul 06, 2011Guide
WOL with NIC Teaming
I have 3 x86 NASs (running 4.2.17) each with LACP NIC Bonding and WOL enabled. All three NASs are connected to a HP Procurve V1810g-24 switch also with LACP configured for the required ports. Here...
Jetlag1
Nov 08, 2011Guide
Sorry to revive and old thread, but I have the exact same switch and am getting ready to set up a trunk on it for teaming my Pro ports.
Curious as to what solution you found (if any)?
Also, which teaming option (on the Pro) did you find the best performance/reliability using?
Thanks.
Thanks.
