fbmachines
Jul 06, 2011Guide
WOL with NIC Teaming
I have 3 x86 NASs (running 4.2.17) each with LACP NIC Bonding and WOL enabled. All three NASs are connected to a HP Procurve V1810g-24 switch also with LACP configured for the required ports. Here...
fbmachines
Nov 09, 2011Guide
I never found a resolution with the HP V1810g-24. HP support basically just blew me off. They sent me a firmware revision that wasn't posted on their website but didn't know if the revision included any fix for WoL with LAG. After that didn't work, they just said "we'll look into it" and closed the case. I haven't heard from them since.
I'm using the Netgear GS724Tv3 switch as my main now because the GUI lockup was fix via a firmware update and is now running stable.
I tried many different bonding types but settled back with LAG because I felt it offered the best performance and I received fewer network error.
Good luck and keep me posted on your progress.
