fbmachines
Jul 06, 2011Guide
WOL with NIC Teaming
I have 3 x86 NASs (running 4.2.17) each with LACP NIC Bonding and WOL enabled. All three NASs are connected to a HP Procurve V1810g-24 switch also with LACP configured for the required ports. Here...
Jetlag1
Nov 09, 2011Guide
I have WoL enabled now (missed that one, sorry).
With the Pro shut down the trunk now shows as "Link Status = Down" but the ports show 100MbpsFullDuplex (green) just as you mentioned.
I tried sending magic packets via both UDP and TCP/IP to the ReadyNAS IP (host) with no response.
Were you successful with UDP or TCP/IP prior to ReadyNAS NIC bonding?
Which port did you designate with the one you were successful with?
