Scouser
Jan 19, 2012Aspirant
Write-cache problems
Is there a way to disable disk write-cache permanently until such time that I might want to turn it back on again. I need to do this manually via some configuration file or command line utility and N...
szlevi
Jan 26, 2012Aspirant
Wow, one week and nobody from Netgear/ReadyNAS gives a crap about your very detailed problem description... OS support must be sucking around here.
This issue just gave me the idea to see if my problem - viewtopic.php?f=23&t=60670 - will disappear if I turn caching off on my Pro 6...
