ScottChapman
Dec 07, 2014Apprentice
Write performance on EXT3/EXT4 is REALLY SLOW!
So, thought this was just an issue with EXT4, but reformatted to EXT3 and am still getting ridiculously slow write performance. Any ideas on how to make it more reasonable? I see that barrier=1 is ...
mdgm-ntgr
Dec 09, 2014NETGEAR Employee Retired
I assume from the above you have SSH access to your NAS?
You could try adding
to your /etc/default/services file, unplugging the USB disk, then reattaching it.
Note, with this option in use you will need to make sure you cleanly eject your USB drives before unplugging them.
DISABLE_USB_SYNC=1
