simath
Oct 07, 2011Aspirant
Write STALLS on first try
I'm running Windows 7 64-bit SP1 with a ReadyNAS Pro 6x1TB (Seagate Enterprise drives with RAIDiator-x86 4.2.19). These are coupled directly via a Netgear GS105 switch. I've been having the follow...
victorhortalive
Oct 09, 2011Aspirant
I used to have this problem. It's due to something in your network setup, usually wrt the IP address/NAS or PC name not being instantly recognised.
I solved the problem by reinstalling all the network drivers and making sure they were the latest. Adjusting the settings on the switch also helped, but your switch is unmanaged I think. Try turning Jumbo Frames off and/or enabling Flow Control.
Are your IP addresses DHCP derived ? If not, try that.
Also see if a direct connection has the same problem - I bet it doesn't.
See : http://sphardy.com/web/readynas/how-to- ... -readynas/
