aegir1
Apr 16, 2014Aspirant
X-RAID (expansion) on Pro4 with OS6
Hi, I just installed OS6 on my old Pro 4. I want to use it as a backup target using replicate. The installation went very smooth and the OS is up and running. Thanks to everyone who made this possi...
mdgm-ntgr
Apr 16, 2014NETGEAR Employee Retired
Can't add smaller capacity disks.
Start with smaller disks first, you may need to reboot once or twice for vertical expansion to take place.
Not sure, as I haven't ever used encrypted volumes, but it's also possible I guess that encrypted volumes have more expansion limitations.
- Sep 06, 2016Retired_Member
