aegir1
Apr 16, 2014Aspirant
X-RAID (expansion) on Pro4 with OS6
Hi, I just installed OS6 on my old Pro 4. I want to use it as a backup target using replicate. The installation went very smooth and the OS is up and running. Thanks to everyone who made this possi...
Skywalker
Apr 16, 2014NETGEAR Expert
Expanding encrypted volumes is a little more restrictive -- we can't do multi-level (mixed disk size) encrypted volumes. If you swap the remaining 500GB drives for 3TBs, it should expand.
- Sep 06, 2016Retired_Member
