aegir1
Apr 16, 2014Aspirant
X-RAID (expansion) on Pro4 with OS6
Hi, I just installed OS6 on my old Pro 4. I want to use it as a backup target using replicate. The installation went very smooth and the OS is up and running. Thanks to everyone who made this possi...
aegir1
Apr 17, 2014Aspirant
Thanks for your replies.
@mdgm: I had initially started out with the smaller disks, then added the larger capacity ones. That didn't work either.
@skywalker: OK, understood. I guess there have to be some limitations with encryption. That now renders the 500GB drives useless, but so be it. They were old after all, I just didn't have any other use to put them to. Out of curiosity: Is it possible to do vertical expansion of an encrypted volume? I.e. what would happen if I were to set up a volume with 3TB drives now and would later replace all of them, one at a time, with 4TB drives? Would the volume expand?
