Slemtiger
Apr 17, 2012Aspirant
X-raid or raid-1
Just got the NAS and installed 2 disks and picket the default X-raid (?). If i understand this right i now have one volum twice as big 2x2 TB. By default it has a "backup" share and a "media" share. N...
Apr 17, 2012Guru - Experienced User
Yes. Putting the same files in both shares is not a backup. It might help with low-level recovery tools if the array fails, or accidental deletion. But it doesn't ensure that you can rebuild the array. In my view that approach is not a very efficient use of the disk space. A true backup on different device is much better.
mdgm wrote: If you stored the files in both the backup and media shares you'd end up with four copies of the data.
Anyway don't confuse RAID with backup. RAID is great but there are a number of problems that it can't protect against. See Preventing Catastrophic Data Loss
You should backup important data e.g. to a USB disk, another NAS, the cloud or some place else, in addition to using X-RAID.
