Anonymous
Sep 06, 2016X-RAID vertical expansion incomplete
ReadyNAS 314 running OS 6.4.0 Was previously running with 4x1TB drives. As we came close to filling that up, ordered 4x2TB drives for vertical expansion. Replaced the disk in bay 1, waited for r...
- Sep 08, 2016
Yes, but you do want to check the disks are healthy, partitions are the correct size etc. before doing that.
Doing it yourself is at your own risk.
omicron_persei8
Sep 07, 2016Luminary
You could try to simply reboot the NAS. Otherwise, I would fail, remove then add sdd4 from/to md126. If you're not comfortable with fixing the RAID yourself, you could try to contact NETGEAR Support.
