Retired_Member
Sep 06, 2016X-RAID vertical expansion incomplete
ReadyNAS 314 running OS 6.4.0 Was previously running with 4x1TB drives. As we came close to filling that up, ordered 4x2TB drives for vertical expansion. Replaced the disk in bay 1, waited for r...
- Sep 08, 2016
Yes, but you do want to check the disks are healthy, partitions are the correct size etc. before doing that.
Doing it yourself is at your own risk.
mdgm-ntgr
Sep 07, 2016NETGEAR Employee Retired
omicron_persei8 wrote:
Actually, you might just need to grow the number of raid devices of md126 from 3 to 4.
Assuming everything is fine, yes. Once the RAID is expanded the volume should automatically expand.
Retired_Member
Sep 08, 2016
Actually, you might just need to grow the number of raid devices of md126 from 3 to 4.Assuming everything is fine, yes. Once the RAID is expanded the volume should automatically expand.
Am I correct that this would be accomplished simply by running
mdadm --grow /dev/md126 --raid-devices=4
from SSH (assuming the system is in all other ways healthy)? Or are there any special considerations introduced by ReadyNAS or BTRFS?
--- EDIT ---
Nevermind, just saw your PM, mdgm. Thanks for the info, I'll give it a shot after some additional checks.
- mdgm-ntgrSep 08, 2016NETGEAR Employee Retired
Doing it yourself is at your own risk.- Retired_MemberSep 21, 2016
Just wanted to say, everything seemed to work out well. Various health checks such as smartctl (and others I no longer recall) came back clean, and, after running the suggest mdadm command the volume expansion began as expected. It completed without issue.
Thanks for your assistance.
- JennCSep 22, 2016NETGEAR Employee Retired
Hello Retired_Member,
We are glad that it works now.
We encourage you to post any suggestion, comments or questions you have that you feel like posting. We appreciate your contribution.
