Retired_Member's avatar
Retired_Member
Sep 06, 2016
X-RAID vertical expansion incomplete
ReadyNAS 314 running OS 6.4.0 Was previously running with 4x1TB drives. As we came close to filling that up, ordered 4x2TB drives for vertical expansion.   Replaced the disk in bay 1, waited for r...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Sep 08, 2016
    Yes, but you do want to check the disks are healthy, partitions are the correct size etc. before doing that.
    Doing it yourself is at your own risk.
ProSupport for Business
