rdebay
Oct 29, 2016Tutor
X-RAID2 lost redundancy - NV+ v2
The front LCD and the admin web page both state that the two X-RAID2 drives are unprotected/Not-Redundant. There are no errors in the logs, both drives are 'green' on the info page, and none have an...
rdebay
Oct 29, 2016Tutor
Just upgraded to 5.3.12, in case that affects the actions I can take.
- FramerVOct 31, 2016NETGEAR Employee Retired
Hi rdebay,
Could you kindly try to send the logs of your NAS?
How do I send all logs to ReadyNAS Community moderators?
- rdebayNov 02, 2016TutorLogs sent
- FramerVNov 07, 2016NETGEAR Employee Retired
Hi rdebay,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- rdebayNov 07, 2016TutorThanks for the reply. I'm assuming there was an I/O error which caused the user RAID to fail, and the system RAID partition is still good. The latest SMART report doesn't show any issues. Since SMART is reporting that the drive is good, I'm going to resync the drive and start pricing replacement drives. Is there any way to resync without pulling the drive and plugging it back in? If not, what steps would I take? Should I pull and reinsert the drive while it's hot, or should I power down, remove, power up, power down, reinsert, power up?
Good day rdebay,
Have your most important files be copied out first to another location (PC, USB HDD). This is fail safe if in case another drive fails during the sync process.
How do I replace a disk in my ReadyNAS Duo v2 or NV+ v2?
If you have an option to gracefully shutdown the NAS, I would advise you to do so. Insert the new drive and power up.
