router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
mdgm-ntgr
Apr 13, 2011NETGEAR Employee Retired
You could try powering down, removing the CF card, connecting it to a PC and writing the 4.1.7 image to it.
