router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
router_exe
i'm going to see if i can't find one floating around here and do that. i was able to update to 4.1.7 again on the stock card. got everything up and running on a 250gb drive.. pulled 250gb drive, and hooked up a 2tb, and tried to factory reset. broke it again...so now trying to factory reset with radiator3x and a 2tb drive...seems to be working so far..just taking forever to create the volume.
