router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
mdgm-ntgr
Apr 13, 2011NETGEAR Employee Retired
RAIDiator 3.x is way too old. What brand and model disk are you using?
The not enough space error possibly indicates enough of the flash has gone bad that the current firmware won't fit on it anymore. A 128MB CF card would give way more than enough room and would be the minimum size that I would go with.
