router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
mdgm-ntgr
Apr 16, 2011NETGEAR Employee Retired
You should do a factory default on 4.1.7 but the NAS should still boot if you don't.
I don't think you've mentioned what model disk you are using yet. This could be important.
