router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
router_exe
Apr 16, 2011Aspirant
ah sorry.
using WD20EARS
WD 2TB caviar greens.
if i do the factory default on 4.1.7, should i have all 4 drives hooked up? or should i add them 1 by one, and hope force expansion expands the volume correctly?
using WD20EARS
