router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
mdgm-ntgr
Apr 16, 2011NETGEAR Employee Retired
I don't know. There's probably a lot more in 4.x which might help explain it.
How much RAM do you have in your 600?
